Kenevo max chainring
c4s2rs6
43
53
Aberdeen
Hi. The stock ring is threaded so if you change you probably need to buy a set of nuts and bolts. I needed to grid about 1mm from each nut to make it tighten enough to hold the ring
Steady_eddy
35
23
Netherlands
Yann smith
England
Maybe it’s the hope ring then. I put a 36t hope 104 BCD ring on my medium Kenevo and it catches on the chainstay, it’s ok whilst on the bike but catches whilst oiling chain etc.
I filed each tooth down a bit but it’s still too close with no sag.
I bought new I.D low profile single ring chain bolt pack from LBS and they fit without any filing down.
Gearing is much better with 36 front. Something Specialized should have sorted IMO.
VaseLEVO
115
75
Arlington, VA, USA
ASV, thats clearly still way close compared to the comfortable fit of that exact ring on the Turbo Levo.
Any of you feel you have lost any noticeable climbing torque going to the 36T? I wouldn't notice it if I did so I am hoping you more expert folk can enlighten us on this.
VaseLEVO
115
75
Arlington, VA, USA
Same here. my bike feels infinitely nicer to ride with the 36T giving reasonable speed without me spinning like the proverbial hungry hamster on hamster wheel. I mostly was only in the lower part of the cassette before but now I find myself using a wider spread and a often in wider mid section rarely going down to the smallest gears but still rarely using the big gears on the cassette. This is more like I was used to on my hybrid and road bikes. I doubt I will ever miss any lost torque.
577K
