Yep will put my brain in gear next time.peddles?
What's wrong with it? It's not even made for the ep8 motor and requires adaptors to retrofit it to the new motor. Also losing access to the extra features you would get from the proper screenWhat it so bad about the E7000 display? No colors? So what? I think any display that doesnt show for example, a map, is not even needed in EMTB. Maybe I'm different but I like clean cockpit with something like EN-EW100.
And the casette. SLX vs XT casette is 60g different in weight.
Needs ragging through some techy rock gardens, see what it looks like on the other side. My guess is bruised.
Any suggestions for techy rocky descents in south UK / wales? Defo want to hit some chunk on this one.Needs ragging through some techy rock gardens, see what it looks like on the other side. My guess is bruised.
Coed Y Brenin Black trailsAny suggestions for techy rocky descents in south UK / wales? Defo want to hit some chunk on this one.
Come to Caerphilly plenty of trails but a bit sloppy at the mo.Out tomorrow for a blast on it. The bike build quality from what I can see so far is really, really good. Fit and finish are excellent. Up there with the best.
Kellys claim this steel- laminate is 2x resistant to impact fracture vs carbon. They’ve told me that they’ve actually been unable to break it on a test rig (but no idea on stats / forces).
What features? Color?What's wrong with it? It's not even made for the ep8 motor and requires adaptors to retrofit it to the new motor. Also losing access to the extra features you would get from the proper screen
Profiles, etc.What features? Color?
Coed Y Brenin Black trailsI know it’s not south but worth the extra.
When do you think you will have the 1st podcast up, been waiting ages for someone to give a proper review, like a kid in a candy storeOut tomorrow for a blast on it. The bike build quality from what I can see so far is really, really good. Fit and finish are excellent. Up there with the best.
First look video out in next day or 2.When do you think you will have the 1st podcast up, been waiting ages for someone to give a proper review, like a kid in a candy store![]()
Thanks looking forward to seeing that, promising so far.First look video out in next day or 2.
First ride yesterday. 42K / 1400 Metres Elevation. Down to 1 bar on the 720Wh battery.
Loads of travel, feels much more nimble than I'd expect a 170mm travel ebike to feel. The chain stay length is 459mm which is quite long compared to a lot of new ebikes. But for me, I actually prefer a longer CS length on a bigger (longer) bike. I feel way more balanced, obviously, I'm more centred weight wise with a bike with 459mm CS and a 482mm Reach.
Rear not quite as supple off the top as I was expecting. Need to have a play around with suspension, rear tyre compound is quite hard too (speed grip Nobby Nic). I'd like to see the suspension curve, I'll ask Kellys for it. Plenty of travel though on tap.
The bike in size L is super easy to move around. Especially at that weight of 22.4 KG and what feels like a lightweight rear end (27.5 / 11 speed Shimano XT / DT H1700 Rims / light(ish) rear tyre.
Top battery carrier bolts came loose on first ride (the underside of the down tube). Didn't look like there was any loctite from the factory so I've added some and torqued them up. Will see how we get on.
Some measurements I did:
Measured actual rear wheel travel: 165mm
BB Height: 355mm
