Gutch
Is this a possibility or is 80 or whatever it is 85nm too much for the frame? Any ideas?
In theory it should be fine, the battery composition will be the same as a Focus Jam/Sam2 @ 376whI reckon they wont allow it because my guess is that the battery 'architecture' or layout/design doesnt allow for the high current drain that full ep8 torque would require.
I have nothing to base this on other than gut feel or conjecture on my part- it'd be nice to be wrong on this.
Cool. Why will the range extender become a problem? Curious, not familiar with stunlocker.I seen someone who owns a rise you are able to increase the power up to 85nm in the stunlocker app,
Once the battery range extender come available in March it would be a problem using the full 85nm.
sorry a type error
you can download stunlocker on android/apple devices in the App Store
They charge a small one off fee
Any bike repercussions?STUNLOCKER
App works with Shimano E-Bike motors via Bluetooth. Allows: - Get E-bike information (total distance, battery health and etc) - Change assist settings - Change gearing type (mechanical, electrical) and chainrings size - Change light settings - Presets for quick setups of your bike - Other...apps.apple.com
Does it function the same as a regular EP8 after doing this or just increase the maximum output? I remember seeing a torque curve from the Rise and it's slow to ramp up, doesn't give power until high cadence.I seen someone who owns a rise you are able to increase the power up to 85nm in the stunlocker app,
Once the battery range extender come available in March it wont be a problem using the full 85nm.
High Rock Ruti
Thanks for starting this. The Orbea Rise with 85 nm would be a real contender, sure it would chew through battery but a short fast blast on an 40 pound bike sounds nice. In terms of the frame? I would think there would be no issues what ever, if it's safe to ride hard over rough terrain, then motor output should not be a factor.
However is the EP8 RS the same motor with software changes, I think I've read that it is. Anyone know?
Warm Regards
Ruti
The Rise is build as a ‘sport’ Emtb , light and fast and with a minimal support for the uphill sections
If you need more power and sufficiënt range with less effort, consider the Wild FS with extra battery
Why add the weight? It’s uncorked torque with virtually no weight penalty or handling characteristics. I think it would be an awesome “option”The Rise is build as a ‘sport’ Emtb , light and fast and with a minimal support for the uphill sections
If you need more power and sufficiënt range with less effort, consider the Wild FS with extra Barrett...
The Shimano EP8 motor is the same as the Shimano Ep8 Rs motor.
The only different is orbea have detuned the motor and used there own software.
yes it is possible to up the power in stunlocker app to 85NM
if you have the extra power pack you will have 612w
There won’t be much difference with Range from a Shimano EP8 motor with 630W
The ep8 motor logs every change to the settings, so yes, it will show on the shop's computer.
Anyway my rise doesn't allow me to choose more than 60nm when using stunlocker, although you can choose more "output power" but not sure how this will affect torque power.
No way to erase all the log files from stunlocker app, not sure about PC app, but probably not possible, even for the dealer because that will break the main purpose of the logs xDHigh Rock Ruti
Is it possible to erase the data files or will that require reflashing the entire computer and some dealer only software or interface tool?
Warm Regards
Ruti
The short answer is yes, I usually ride uphill in trail mode. The only "problem" is that sometimes I need the boost mode for some very tough uphills and the power is not enough compared to my giant pro 80nm motor.
Hi have you derestricted your Rise or changed to US 20mph with Stunlocker ? Any thoughts a few weeks on ? I’ve an M10 so thinking about next stepsThe ep8 motor logs every change to the settings, so yes, it will show on the shop's computer.
Fair enough early days ?No I did not... too soon to lose warranty yet
