That would be neat. Fox has a system called Live Valve, that automatically adjusts the suspension on the fly extremely fast from sensors. They have something called pitch detection, so it knows when you are climbing. Seems like the tech is already there for it to automatically reduce your forks travel for a steep climb.Absolutely just needs AXS and I'll order one for sure.
If I had to guess I'd say the next year or 2 or maybe that's a bit optimistic?this will eventually happen in the next 15 years
1:10
Exactly this was done in 4X 15 years back. And way before that it was available on XC forks.I used to race dirtbikes when I was younger, I have always wondered why no one has done something like this for mtb's. I am sure there are many ways to do it; this would make extra travel up front a non factor for climbing.
@1:10
A manually operated version already exists.
Both main players have different variations of reduction in fork travel which is controlled via a switch on top of the fork. On my Lyrik you can go instantly from 180mm to 150mm just by turning the switch clockwise and back again by turning the switch anti clock. This has been available for years.
On Rockshox forks it’s called dual position air.
On Fox forks it’s called Talas.
I have a Lyric Ultimate - FS-LYRK-ULT-C2.
All the user documentation is generic and covers about 10 different versions. How do I know if I have this feature? I think from memory I just have HSC and LSC on the top.
My father in-law has a Stumpjumper S-Works from 2011, and it can switch to lock the forks half travel for climbing.
Not a xc weenie personally. You seem to get wound up quite easily haha. I guarantee you couldn't climb what I do, on anything. #internetflexExactly this was done in 4X 15 years back. And way before that it was available on XC forks.
Do keep up moto guys.
Makes some sense for gate starts but It's absolutely not required for climbing.. Skills are. Far too many folk look for shortcuts though. I don't really get that type of rider. Not gaining skills would kill the entire point in riding for me.
shorter cranks will assist you so you can be lazy and unskilled and forget the trail underneath your pedalsNot to be a spoilsport ..
But don't most people find they end up climbing in way more places they did on an a clockwork bike, because you can, which leads to more pedal strikes - because you just wouldn't have done it before .. (which can be mitigated by skill, ability, thought, use of eyes, timing, jet packs)
If you dropped the nose 150-180mm wouldn't you then need to install old shoe soles on the undersides of your pedals (the added weight should make the pedal self righting) and have crank crampons to aid in climbing ?
What makes you think you've wound me up?Not a xc weenie personally. You seem to get wound up quite easily haha.
#prettyweakhumblebragI guarantee you couldn't climb what I do, on anything. #internetflex
What??Not a xc weenie personally.
The motor just makes it easier... waaay easier.
What?? lolExactly ! Someone like you who's rated "God like" compared to someone like me who's rated "Mycoplasma", finds it "Easier", means I find it "Possible" .
