I need Help!
kcarbon
241
140
australia
hope someone can help, took rear wheel off and pushed the lock button on derailed to hold chain for easy wheel removal.
now can't seem to get it to unlock. Sram on 2018 Levo Comp Carbon. thanks in advance
Geoff
65
57
Push the back of the cage behind the lower jockey wheel in the direction of the front of the bike until the button pops out then whilst still maintaining pressure on the cage let it swing back until the chain tension returns to normal.
Krisj
313
530
Sheffield
Try what Geoff said and while holding it forward try and get a small screw driver in from the back to push the button back out also some lube around the button but be careful not to spray near your discs
kcarbon
241
140
australia
thanks for advice, I went to bed, now early next day I was thinking I'll spray WD40 to free it up, as might have dust making the pin stiff to release.
Mike it's very useful when removing rear wheel it has a lock marked on a button, push derailed forward push button and it holds it.
555K
