Hydraulic gears ?
Slowroller
494
496
Wyoming
The main issue with most if not all current gearbox systems, either bb or hub mounted, is that you cant change gear under load. Irrelevant of the motor, the moment someone comes up with a relatively lightweight BB base gearbox that can shift under load, and doesn't rely on a grip shift type shifter, it will change the MTB industry overnight.
The Mubea uses this gear box, shifts under load, coasting or stopped and can use a SRAM trigger shifter.
Effigear⎮Bicycle Gearbox⎪Boîte de vitesses vélo⎪France | LA BOÎTE En
Carlos Muralhas
94
78
Portugal
Not true with any solution based on continuously variable planetary (CVP) gearboxes - like the NuVinci 380 for instance.
Continental presented an eBike motor on Eurobike with an internal NuVinci gearbox that does manual or automatic gearing. Too bad it's so heavy...
First ride: Continental 48V mid motor system with automatic gearing
ccrdave
1,428
1,125
uk
there used to be a car, a DAF i think that had an auto box based on a sliding belt as the car went faster the belt slid to the narrower side on a drive which was cone-shaped no gear changes just seamless drive action. I wonder if that could be implemented in an e bike
Carlos Muralhas
94
78
Portugal
Functionaly that's exactly what a continuously variable planetary (CVP) gearbox does. Continental just presented an eBike motor with an internal continuously variable planetary (CVP) gearbox (see previous post).
Carlos Muralhas
94
78
Portugal
Yes we already discussed that earlier in thread, but a CVP is a different concept to manual gears
It's gears nonetheless, from easy to hard gear (with a 380% variation in the case of NuVinci 380). We don't really need gear 1, gear 2, etc, we need gering from easy climbing gears to high speed gears. If they are continuosly variable is even better, you can ALWAYS be in the right gear for the situation and they shift easily during load.
My experience of CVP/CVT in cars and motorbikes is that the gear the gearbox thinks you need is quite often not the one you want! If it can be made to work, brilliant.
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
We need to get the derallier hanging gubbins higher up away from the ground .
Silly question ..could the mechanism be mounted above the cassett? Must have alook in the morning.
Trouble with EMTB development is I now want another bike.......:LOL:
Yes! Just need to pedal backwards :oops:. Although, that presents another problem...o_O, well at least a couple of problems...Silly idea.
OldBean
602
528
East anglia
My erotic dream has arrived ....just needs full suss......Gimmi Gimmi Gimmi
speedkills
230
221
Boulder, CO
This looks like a motorcycle gearbox to me, which seems a good place to start. I wonder if they'll get off of the ground? Having owned an alfine and a rohloff I'm not a fan of the planetary gear based solutions in their current form so always keeping my eyes open for something better.
571K
