JC-1
This afternoon, when I was loading my Rail onto the car, the Rocker Axle Nut (30) fell onto the ground. It's stripped and the bolt has pulled through, I assume because it was loose while riding. I tried to remove the Rocker Axle (26) to check it over, but it spins in place. I've given it a decent tap to knock it through from the nut side, but it isn't budging, other than spinning with a hex key.
Is there some trick to removing it? I'm not sure what would be holding it in place. Maybe the Main Pivot Sleeve (27) or a Rocker Axle Spacer (28) is damaged and somehow holding it in. Any help would be hugely appreciated!
