Levo Gen 3 Hope V4 mounts?
Jase
100
163
I have bought some Tech4 V4 brakes for my Levo Expert, do I need new mounts also, or has anyone fitted and used the ones that come with the codes?
If I need them which I suspect I will does anyone know which ones I need. Have the hope heavy duty rotors 220 front and 200 rear to go on.
Ou812
765
520
Inverness
You’ll need HBMM for the front and HBML for the rear if you’re buying Hope mounts, so just “M” and “L” if you’re buying online. I’m running the same set-up on my Levo, the V4s wouldn’t work on the SRAM mounts without some grinding for clearance.
  • Helpful
Reactions: Dax
Jase
100
163
Cheers I have some on order 👍
554K
