Jeff McD
Hey everyone, I have been considering a mullet conversion of my 2020 levo for several months and after reading all the positive comments on the 2022 levo mullet configuration I'm going to go ahead and do it. Already have the flip chip in the high position but still get pedal strikes in our extremely technical terrain with so many rocks, because the flat pedals are so big and wide. Other than shorter crank arms what can I do to avoid increasing pedal strikes as the mullet rear wheel will have a smaller diameter than stock 29 using the same tire? Should also add that I put a 160 mm fork on, if that makes any difference. Thanks in advance for all advice.
OK so I edited this post to try to be clearer. I'm looking for a shock yoke that I vaguely remember reading about that might raise the bottom bracket a bit. Is there such a thing?
