brw0513
Hi all.
I purchased this bike a few months ago and I'm really enjoying it. Mostly just commuting to work to get to know it before heading to my local-ish trails.
Originally, there was some chain noise in the tallest gear, but it is now happening in 10th and even 9th gear. The rear derailleur adjustment settings (to set the overall angle and the high and low travel limiters) seemed a little strange since they appeared to be toward the very end of their available range.
So I started reading Shimano's documentation that is easy enough to find online. I suspect my chain is too long and, in the higher gears, is making contact with itself at times when traveling through the derailleur. It's not the original KMC chain, but a Shimano branded chain.
I think the Fox Float X2 has 50mm of travel based on where the "dust ring" has settled.
As shown in the photos below:
* the shock has been disconnected and the rear axle raised to give 50mm between shock mounting eye and the eye of the suspension linkage.
* the chain is on the largest gear on the cassette.
* the bent wire is fitted in the bore of the link pins to give the shortest possible chain length for this arrangement.
Please confirm the chain is too long and should be cut where shown by the "red line" indication and that this cut link then replaced with the quick disconnect link.
Thanks.
Thanks.
