thegorilla
Hi all, I'd like some advice on what adapters to get so I can install Code RSC (used takeoffs) brakes and Magura MDR-P 220mm discs on to my 2019 Turbo Levo FSR.
The bike has what I assume are the factory (bought bike new as a demo) SRAM Level-T levers, and I don't know calipers, and 203mm discs. (photos attached)
I'm a bit confused by the different spacer/bracket terminology., I've attached photos of my brake brackets.
Front: The best I can tell, my bike has Fox 35 fork (is that a thing), and fork mounts for 180mm disc, with a 20mm adapter bracket.
Rear: The rear looks like frame mounts for 180mm disc with a 20mm bracket.
Are Magura QM45 the correct adapters to get for both front and rear? Magura QM 45 Disc Brake Adapter - 180mm-220mm Rotor (Front) or 140mm-180mm Rotor (Rear)
MDR-P 220mm Discs (for reference) : Magura USA | MDR-C and MDR-P ROTOR MDR-P 220MM (80002301144)
Magura guide: https://www.magura.com/media/1061051/2019-08_mounting-guide.pdf
Thank you in advance!
