Help choosing my girlfriend's first emtb
Zayd Proctor
42
15
Italy
Having built my first emtb, I now need to get one for my girlfriend who, like me, is new to both emtb and mtb. I was thinking something used, under 3000€. Entry level components will do just fine.
I think the most important thing here is the choice of motor. Ideally, I'd go with the Bafang M510 because it works with custom batteries, it's serviceable, it can be derestricted, it's easy to upgrade to the M560 if needed.
The problem is that there aren't many offerings with that motor. The best I could find is this refurbished Berria Mako for 3100€.
I have no idea how the other motors compare with Bafang. This is where I need your help. What would you choose?
Here's a comparison of the main mid-drive motors for eMTBs, covering their pros and cons to help you choose the best one for your needs.
🔧 BAFANG (M500, M600, M620)
💡 Best for: Custom builds, high power, DIY enthusiasts
✅ Pros:
✔ High power & torque (M620: 160Nm, M600: 120Nm)
✔ Open system → works with aftermarket batteries
✔ Customizable via third-party apps & programming
✔ Easy to repair with widely available parts
✔ Affordable compared to premium brands
❌ Cons:
✘ Less refined power delivery, can feel jerky
✘ Noisy at high torque levels
✘ Can overheat under sustained load
✘ Heavier than Bosch/Shimano motors
⚙ BOSCH (Performance Line CX, Smart System)
💡 Best for: Reliability, smooth power delivery, premium eMTBs
✅ Pros:
✔ Excellent power curve & natural feel
✔ High reliability & premium build quality
✔ Strong dealer support & service network
✔ Smooth integration with eMTB components (ABS, Kiox, etc.)
✔ Good battery efficiency
❌ Cons:
✘ Requires proprietary batteries
✘ Firmware locked, no DIY tuning
✘ Expensive motor & parts
✘ Some overheating issues on long climbs
🔵 SHIMANO (EP8, E8000, E7000)
💡 Best for: Lightweight builds, natural pedal feel
✅ Pros:
✔ Lightest mid-drive motor (~2.6kg for EP8)
✔ Smooth, natural pedal assist
✔ Compact design with good ground clearance
✔ Efficient power usage for longer rides
✔ Works well with standard MTB drivetrains
❌ Cons:
✘ Less torque than Bosch/Bafang (EP8: 85Nm)
✘ Can overheat under heavy loads
✘ Sensitive to firmware updates that may reduce performance
✘ Limited aftermarket tuning options
🔴 BROSE (Drive S Mag, Drive T, Specialized Turbo Levo/Kenevo)
💡 Best for: Quiet operation, premium feel, integrated eMTBs (Specialized, Rotwild, etc.)
✅ Pros:
✔ Smoothest & quietest motor in the market
✔ High torque (90Nm) with natural power delivery
✔ Compact & lightweight (~2.9kg)
✔ Good integration with premium brands (Specialized, Rotwild)
✔ No resistance when pedaling without power
❌ Cons:
✘ Brose motors have had reliability issues (belt failures, water ingress)
✘ Proprietary system → harder to repair or customize
✘ Limited third-party support & expensive replacement parts
✘ Specialized versions locked to their ecosystem
🟡 YAMAHA (PW-X3, PWseries S2, PW-X2)
💡 Best for: Power & durability, alternative to Bosch/Shimano
✅ Pros:
✔ Strong torque (PW-X3: 85Nm)
✔ Reliable and robust build (good for long-term use)
✔ Works with both proprietary & third-party batteries in some cases
✔ Responsive motor engagement (good for technical trails)
✔ Less software restriction compared to Bosch/Shimano
❌ Cons:
✘ Heavier than Shimano/Brose (~3.1kg)
✘ Power delivery less refined than Bosch/Shimano
✘ Fewer eMTB brand integrations compared to Bosch/Shimano
✘ Aftermarket tuning options are limited
🏆 Which One to Choose?
MotorBest ForTorque (Nm)Weight (kg)CustomizationBattery FlexibilityReliability
Bafang M600/M620Power & DIY120-1603.6-5.3🔧 High🔓 Open⚠️ Moderate
Bosch CXAll-round performance852.9🔒 Locked🔒 Proprietary✅ High
Shimano EP8Lightweight, smooth ride852.6🔒 Limited🔒 Proprietary⚠️ Can overheat
Brose S MagQuiet, premium feel902.9🔒 Locked🔒 Proprietary⚠️ Past reliability issues
Yamaha PW-X3Durability & power853.1🔒 Limited🔓 Semi-open✅ High
🏁 Final Thoughts
  • If you want customization & repairability: Bafang 🔧
  • If you want premium reliability & smooth ride: Bosch or Brose 🏆
  • If you prefer lightweight & efficiency: Shimano EP8 🚵‍♂️
  • If you need durability & power: Yamaha 💪
Which motor are you considering? 🚀
Zayd Proctor
42
15
Italy
Then go Bosch.
Well, it's not that simple. She prefers the Bosch solely for the way it delivers power. And, as I said, it's a preference by a small margin. But there are other things to consider, like the reliability, reparability, the quality of the other components, and price. That is my assignment and, at the moment, I think that the Raymon is the better package. I need to look into the reliability/reparability and then make a decision. And, of course, I already told her all this and she agrees.
571K
