Beekeeper
🍯Honey Monster🍯
Lightly rotating handlebars left or right produces terrible creaking, really quite loud. Any ideas what could suddenly be causing this?
What is it with that? That is widespread through the motorcycle and bicycle industry.Did you grease the Cube headset bearings Beekeeper? For some reason they dont on assembly.
They out of a old bmx ?Finally removed headset and I noticed about 3 of the ball bearing are either cracked or completely crumbled (photo below). The bottom caged bearings look fine.
I’ve ordered a new top set of bearings.
these cage type bearings look rather cheap and nasty compared to the cartridge type. Am I stuck with these forever or is there an equivalent cartridge set I could swap in at some point in the future? Otherwise I’ll just stick up on a few of these cage types.
also, which type of grease should i use for my replacement caged bearings when they arrive?
