GX AXS issue
rossctr
Bexhill
I currently have a 2024 Whyte E-160S running its stock drivetrain, AXS (not T-Type), Whyte hubs HG freehub, 12s SRAM cassette and its running beautifully.
I've got some ENVE M730 rims on DTSwiss hubs i want to use but it wont shift into the biggest gear. Everything is the same as the stock wheels, boost and the same SRAM cassette other than its a XD freehub.
Tried all the micro adjustment in app but it just wont go up that high on these wheels, any ideas?
Cheers guys
rossctr
Bexhill
I tried this when the bike was brand new, it didnt work so just put the stock wheels back on.
It shifts perfectly as it is, its just on the DTSwiss hubs its like the cassette sits closer the centre.
9,676
The cassette just has to be in a slightly different lateral position for this to happen. Problem is that if you adjust anything except the cassette position then you won't be able to put the old wheel back on.
If that is not a problem, then start from scratch and reset the shifting as though it was new.
Jackware
Fat-tyred Freakazoid
2,129
2,336
Lancashire
Googling DTSwiss cassette spacer does being up results, maybe check if one is listed for your particular rear hub?
6,673
5,155
Assuming limit screws are not stopping it reaching the biggest cog it would appear it can only be that the cassette is in a different position compared to your original set up.
It could be that the wheel build on ENVE rims has the hub spoked with a bias towards the disc side, so taking the wheel into a wheel builder to check for any hub offset may solve the issue. Which DT Swiss hub is it? My Whyte E160 RSX ( 2022) runs the original AXS and the wheel is the DT Swiss HX 1700 with steel XD ratchet freehub so I am less convinced it is a DT Swiss issue.
562K
