It seems that adding 10mm of fork travel change the slack angle 0.5 degrees. So does that mean that running 160mm front + low position for the mino link is the same geometry as running 170mm with high position?
I am debating between a Fox Factory 36 160 or a 38 170. I am unhappy with the Yari, harsh feeling especially on rapid small bumps.
Also, with the new 2021 DHX2, will the 230x65 fit? I know the 230x60 is ok, but wondering for the 65 which would be great travel. Also, what mounting hardware to order?
