frame Bearings on Cube stereo Hybrid 160 2020
Frankieboy
293
225
Basingstoke
You can buy sets made up by Cube from a number of LBS, in which case you’ll get the bolts also in many cases. If you can remove the bolts without damaging them, and they haven’t been damaged by worn bearings, you can just replace the bearings. In that case you can buy bearings individually from many outlets.
I’ve replaced most bearings on all my bikes in the last couple of years and have bought them from Home page , as they have a wide range of bearing and seal types.
You may also want to consider bearing removal tools, the outlet mentioned above put me on to this supplier Bearing Pullers and Presses for Bicycles - BearingProTools.com who specialise in bike bearing tools. You can buy tools specific to each bearing size.
davidjmilli
27
22
Dudley
does anyone has a list of all the frame Bearings on Cube stereo Hybrid 160 2020?
i found this list, https://www.cube.eu/fileadmin/2020/Service/Bearing_Sets_Lagersets_2020.pdf
but is makes me more confused.
are we suppose to replace the bolt each time as well?
Hi. If your still after the bearings list. These are what we’re needed to swap mine out. 2020 160SLT
6902rs x2 for rocker mount
6902rs x2 for main pivot
63801rs x4 for rocker pivots
608rs x4 for swing arms
They are all included if you buy the cube bearing sets from the likes of infinity cycles however if you do not need the hardware it’s much better especially if you prefer to swap out the bearings with better quality pieces. Full bearing set worked out around £130 where as full set of bearings was £55 for Enduro MaxFill bearings.
Only thing I would warn about with the 6801rs for the rocker pivots is that you make sure those you buy are of the 7mm wide type. A standard 6801 is only 5 mm. it’s the 63801 that’s needed if you go with Enduro 2RS type. Took a while to figure this one out as not even my LBS got it right first time round.
552K
