Fox Transfer Command Post, anyone?
Galion
99
119
Brazil
Hello, ready to order a Fox Transfer Factory Post for my 2020 XL frame. I am so confused regarding post lenghts and diameters.150mm or 170mm? 30.9 or 31.6? Specialized comes with 34.9 so I already know I need a shim. Any downsides? please advice.
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Not sure but maybe the shim is the downside. If so, have you looked at the Reverb AXS? No shim or routing hydraulics, long service intervals and it is very good.
Galion
99
119
Brazil
I am a little apprehensive on that one too, but being kind of OCD, I’d like to match the dropper post to my Kashima fork and shock
net wurker
185
237
Huntsville, AL USA
Are you sure that 34.9 isn't the seat CLAMP diameter? I think that is the standard clamp size for frames with 31.6 seat tube diameters.
And, I have a FOX Transfer on my acoustic bike, very nice, very reliable. Almost two years on it, no service yet and it still works flawlessly. I have it paired up with a WolfTooth remote, also a very nice product.
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
That's the only downside I think.
Mix & match, choose whatever feels best. I've only read excellent reports about the Reverb AXS except my own when it was bricked by a firmware update. I got it back very quickly despite being bought online. Not a real problem because it's so solid, quick and precise.
Nice pooch!!! Is that a panther or a black Great Dane?
Snatch
38
9
Warwickshire
I will sell mine 3 months old from 2019 turbo levo comp £150 posted uk inc lever 34.9 and 150 mm
paquo
463
283
usa
i used a ks lev integra 34.9 with a kcnc clamp. With this setup you can use the specialized lever and cable housing so it is plug and play. Rescue dogs rule !
salko
1,275
867
SLO
Hello, What size is your Levo? Mine is XL, not sure if I need a 150mm or 170mm Dropper
Here is data about dropper posts of stock Turbo Levo 2020 bikes:
  • S-Works: RockShox Reverb AXS, 30.9mm, S: 125, M:150, L/XL: 170mm
  • Expert Carbon: Command Post IRcc, 16-position micro-height adjustable, two-bolt head, bottom mount cable routing, remote SRL lever, 34.9mm, S: 130mm, M/L/XL: 160mm of travel
  • Comp: X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm
All Mountain Coaching
1,332
980
GB
I got a shim down to 30.9 from superstar for about a fiver. Have had 2 fox droppers, the 150, now the 175 on an XL. I'm 6'2, wear 34 leg jeans and have about an inch of post still showing. If that helps....
Galion
99
119
Brazil
View attachment 21542 View attachment 21543
This is very helpful, thanks.
Do you know if its possible to insert the post all the way down to the seat tube collar? Looks like a 175mm Fox dropper may be a bit longer than the stock 175mm X-Fusion.
TrackRat
64
34
SchnellerGT981
Just installed the 175 Transfer on my medium 2019 Levo. Have noticed that if I compress the seat all the way down it will slowly release. Over a 10+ hour period of crept up maybe 1.5 inches. Is that normal?
tacoma22
70
57
California
I have not noticed if mine does that, I also have the 175 2021 transfer, but I also keep my droppers in the up position while stored at home as I think that is better for the internals.
Craigski
hi did you just pull the inner cable back with the old post and re-run the new on the same inner without moving the housing?
Im thinking of doing same on rise but worried about outer housing routing round battery and motor?
was hoping I can just pull inner back with old and pull through with new.
Any thoughts welcome?
tks
TrackRat
64
34
SchnellerGT981
I don't see why you couldn't reuse the original housing unless its torn up. If you do run new outer definitely buy the RockShox double barb connector. I used it last week for running new brake lines thru the frame and it was a huge help compared to manually snaking the dropper post outer a few weeks before that
tacoma22
70
57
California
tks
You probably could just pull the old cable through and leave the housing. Then push the new cable through. That seems like a smart idea I did not do lol.
I took it completely out and re ran new housing but same original cable. Mainly because my cable cutter kept botching the cable so I just re used the old one. I got a good cut on the old one and just went with it. It was not very old cable anyway. This was on my Hightower though and not the levo so can’t speak to running it around the motor.
grantini
611
539
Delaware
Just replaced the stock dropper on my 20 expert Carbon SL with a transfer. I’m considering putting one on my 20 Sworks and ditching the AXS. I put one on my first ebike which was a an 18 base Levo. Best dropper I’ve had.
553K
