Flow not recording route on map
Andy.M
176
105
Rochester UK
Done 10 rides now. Mostly all been recorded ok.
The 4th ride didn't record the route on the map.
The 9th ride did record but not following the actual route. Just tracing vaguely in the right direction with one wildly out detour of a few miles!
Today the 10th ride and again no route on map.
When it doesn't record there is also insufficient data on the elevation report.
Iphone is set to allow app to use location services.
Any ideas?
Andy.M
176
105
Rochester UK
Just curious if you watch it real time during ride or if phone is just in your pack and check afterwards?
Good question! I have phone in my pocket.
I did a bit of googling and only discrepancy I had was that my phone location services was ticked only while using app. Yesterday I changed it to always allow. I did two rides and both recorded everything as normal.
Going to try again later today. Fingers crossed it’s sorted but it’s strange how it worked at first.
RustyIron
1,949
3,068
La Habra, California
That' makes perfect sense. A friend doesn't use the Flow App to record rides because she experienced the same symptoms that you originally reported. I'll suggest she review her settings. Thx.
killerade
49
45
Slovenia
I had the same problems with the Flow app. Make sure to allow the app to use location and disable auto-kill — the app should always run in the background. Just make sure Android doesn’t kill it.
578K
