Levo Gen 2 Fitting Hope Tech 3 V4 braided hose
Roger20
145
104
West Yorkshire UK
Can anyone give a definitive answer as to whether its possible to fit braided hoses in the conduits of a Specialized Turbo Levo (2019/20). I have read that Hope say a braided hose is the same 5mm diameter as the normal black hose.
However I have also read, possibly on this forum that it's not possible for some reason. Would just like to hear from someone who has either done it or tried and failed.
DC101
22
7
Kent
I fitted hope braided lines to 2 2020 kenevo's with no issues. Best advice is to get yourself a Rockshox barb tool. Pull the new hose through with the old one.
Roger20
145
104
West Yorkshire UK
Thanks - just what I wanted to hear. Any need to lubricate or did they just pull through using the barb tool?
What do you think of the Hopes? I have Guide REs which are OK but seem to need a lot of maintenance whereas Hope Mono Minis over nearly 20 years have been virtually maintainenance free apart from pad changes.
DC101
22
7
Kent
I did use a little bit of gt85 on one of the bikes, but didn't really need it. The other bike was brand new so didn't bother.
I cut the stock hose at the caliper, and the hope at the master cylinder. Attached the 2 hoses together and pushed them up through the frame. Can apply some slight pulling force, but mostly push the hose through.
I really like the hopes. I run V4's on all of my bikes with no issues. Had 1 leaking seal on the rear caliper (brakes were 2 years old). £5 for the hope seal kit and 30mins work and they are back together. That has been the only issue I have had.
bluewater87
135
55
Canada
I have had hope normal and braided lines.
the braided are definitely bigger.
552K
