Specialized release 2019 Kenevo Comp £4250
Finch9981
48
23
Tyne and wear
so rumours of a 2019 kenevo comp, on a fbook group at the minute with a guy posting a picture claiming its his, seems odd absolutely nothing in the way of a statement from the specialized yet, thoughts? 180mm pikes apparently
[Rob Edit]
Full specs:
  • Frame - M5 Aluminium
  • Fork - RockShox Yari 180mm
  • Shock - Fox Van RC Coil 180mm
  • Drivetrain - Shimano SLX 11 Speed
  • Brakes - Sram Guide RE Hydraulic Disc
  • Motor - Specialized 1.2E Custom 250W
  • Battery - Specialized 460Wh
Kiwi in Wales
Short cranks rule!🏴󠁧󠁢󠁷󠁬󠁳󠁿
1,241
1,589
Carmarthen, Wales
Apart from the cheaper version coil shock and the colour I cant see many obvious 2019 changes, hopefully a big reduction in price.
I would say the fork may be a Yari as Pikes do not come in a 180mm version.
It still looks bloody nice!!!
Finch9981
48
23
Tyne and wear
Apart from the cheaper version coil shock and the colour I cant see many obvious changes :(
the guy who posted reckons they are pikes and made just a for the kenevo as this exact question was asked. i much prefer the cali fade colour scheme though
According to my LBS 2019 Spesh EMTBS due in with Specialised UK in 2 weeks, they had heard rumours of bigger range of bikes and maybe the bigger battery
Finch9981
48
23
Tyne and wear
I called Berkshire bikes earlier, couldn't confirm the price but advised they would likely be on average 12% lower than rrp. the lower batter capacity is a bit of a put off though
Richt20000
194
112
Uk
Yea, it it has been lower spec but same motor and bat then I would have jumped in as I already have some fox 36 180mm and carbon hoops. But I’d rather wait for the sales and pick up a 2018 kenevo for 3600-3800 in a month-3 months
Doomanic
🛠️Wrecker🛠️
8,717
10,381
Or lots of shops all trying to sell the last few in the Spesh warehouse... :D
Mgbudd
52
59
Chichester
I spoke to LBS and looks like expert version of the kenevo for 2019 is unchanged apart from the colours. They have dropped the green, black continues and the will have a Matt blue colour. Comp is cheaper with smaller battery and lower spec fork - Yari, also 1.2 motor
Finch9981
48
23
Tyne and wear
the green was my favourite colour, do you you know if the blue is a solid blue or a fade like the green was?
554K
