Cant remember seeing anything on here about cleaning the electrical contact points on the bike. I dont know if similar connector plugs are used on other brands but the battery to motor connector on my Levo is magnetic. That is good from the point of view that the connection does not wear but because the contacts are not the insertion type they do not self clean....oxidation is therefore the main potential problem and the eventual cause of a bad connection. Again I do not know if the electronis employ the use of a wetting current to ensure a good connection or not. Regardless seems to me fairly regular cleaning of the contacts with a good electrical contact cleaner is good practise.
