E8000 vs EP8 with same battery
mas
60
35
Just wondering:
If you had the same bike with the same 500Wh battery but one with an EP8 and the other with an E8000 would the EP8 get noticeably more range or just the same?
In the EP8 are any efficiency gains just offset by the increase in Nm?
MAS
20,757
I guess it would depend how you rode.
If you mainly did easy going trails in Eco, you might get slightly more range from an EP8 than from an E8000.
If you ride a lot of steep stuff, try to ride fast and mainly use trail and Boost, then there's a good chance you'd get slightly less range.
Would be interesting to hear from someone with similar bikes with the two different motors ridden over a period of time though.
552K
