e160 RSX 2024 Spec Sheet
6,470
4,950
thought this might be useful (see attached).
Could anyone with the same bike tell me whether the B stop adjuster on their GX AXS mech is aligned with A or B please.
  • WE160RSXV2.pdf
6,470
4,950
my reason for checking that mech B gap position and chain length ( 120 complete) is that I noticed when I have the bike in the stand, changing into the largest 52t cog the guide wheel is very close to/almost touching that 52T cog. I never use that cog when riding so not that bothered and of course once the bike is on the floor the B gap is extended a little due to SAG.
The reason I change to the 52T when on the stand is so that when I oil the chain it is only that 52T cog that gets oil on it ( oh, and the jockey wheels of course) and it is easy to wipe off.
It did make me wonder if the chain would actually foul the 52T once the chain has stretched a little!!
Davvee
137
87
Mansfield
This is mine. Hope it helps
Mik3F
431
355
Middleton
Can't say I have noticed that to be honest, but then I don't use 52t much anyway, and when in a stand I only quickly cycle the gears when degreasing. Usually lube in 5th or 6th myself
6,470
4,950
Same as you guys...I checked mine and it is on Position B and the chain length is 120 ( complete with powerlink). So thanks for the input.
ttard
New member here, but 'lurking' since July. I have a 2024 V2 E-160 RSX (XL Size), which is set up in Position A (by the supplying dealer). I've also inputted the bike details into SRAM's online 'Calculator' (SRAM | AXS) which also confirms Position A. Screen grab attached. Any thoughts?
6,470
4,950
only that the title E160 is not very specific either in terms of model year or "s" "RS" "RSX" and could even include the previous MX models.
549K
