All of this may be common knowledge to some but if not ...Read on.
I have a Whyte E180RS very nearly a year old now albeit fairly low mileage since I also have a Levo Comp. Apart from changing pedals and seat...and some adjustment to bar width and position I have done nothing to the bike except clean and lube.
The bike has DTSwiss 1700 hybrid wheelset which uses hybrid 350 hubs, xd driver, 24t ratchet engagement system and SRAM EAGLE 1275 cassette. I am very familiar with the Levo 3 pawl hg driver and hub set up but the DTSwiss 350 is new to me.
So, everything still working fine but I service the Levo freehub every 6 months so thought it was time to tackle the Whyte. The freewheel noise had become quite loud and I know that is one indication a service is due.
I suspect the process is similar for any DT Swiss freehub/hub.
So having removed the wheel from the bike the process is:-
1. Use a standard shimano cassette tool and chain whip to remove the cassette. I found the type of cassette tool with the 12mm shaft best because there is not a lot of depth for it to secure. The cassette comes off as a single piece since all cogs are pinned.
2. Next remove the end cap. You can use tools like a plumbers adjustable wrench with cloth to protect the end cap....or use the 12mm extension of the cassette tool. Either way it is levered off rather than pulled.
3. The XD driver can then be gently pulled off the axle being careful not to loose parts. Starting at the freehub you will have a spring then 2 ratchet rings and then another spring probably still in the hub and a sleeve that slides off the axle. Note each spring is fitted with its smallest diameter towards the ratchets. Note also the ratchets are identical but are fitted with their serrated faces facing each other.
4. You can now clean everything and inspect both freehub and hub bearings. Mine were all smooth so no further stripping of hub or freehub was required.
5. The ratchets ,springs and ratchet rings in the hub and freehub need to be lightly greased with the red DT Swiss Special Grease. The bearing faces, axle xd driver thread, inside of the cassette and end cap seal can be lightly greased with a general purpose grease (lithium based).
6. Reassemble the driver and ratchet system and push the end cap back on.
7 . Present the cassette and ensure it locates on its castellations then tighten the cassette with the cassette tool to 40nm.
I was amazed how clean everything was with no evidence of water or dust ingress. There was however virtually no sign of any grease!!
