Disc rotor 203 for H15
Trail Blazer
65
28
Sweden
Im waiting on delivery on my H15 will upgrade to 6120 4 pistons and 203 discs. I will go with Ice Tech Shimanos but they seems to come with 2 different diameters?
What kind of post mount adaptor will be needed?
I have tried to find answers in thread but its a bit inconsistent
Thanks 🙏
TtheArab
97
56
Hayabusa!303
How did this go ? Also what forks are you using ? I have a set of Fox 36 Float Factory coming to fit to new purchase but some confusion around the 180-203 Adapter as there appear to be 2 in F203P/PM and F203P/PA.
Rod B.
530
923
USA, Orange County Ca.
Thanks 🙏
Tjone,
I did a three part technical article on modifying Rise brakes. Part # 2 of the series covers everything you need to know in regards to modifying the brakes on your Rise, including charts which list the part number of the caliper adapter you will need to get for each size brake rotor. The series also covers Shimano brake lines and brake pads, and other miscellaneous stuff you will need to know in regards to Shimano brake systems.
part-1-shimano-brake-system-service.29086/
part-2-shimano-brake-system-%E2%80%93-orbea-rise-brake-system-modification.29158/
part-3-shimano-brake-system-service.29313/
553K
