Hi all I've got a 2019 trance 3, it came with a suntour aion 35 which worked fine, but I found a yari for £239 so bought it and fitted it my suntour at 160mm is 572mm measured but the yari at 150mm is 542mm measured obviously its steepened the head angle from 64 to nearly 66 that's bad but when I've looked the yari at 180mm is 572mm axle to crown measured so I'm thinking take the spacer out my fox shock and ill have 152mm ish travel and 180mm front any thoughts ?
