• Warning!!
    UK Pedelec Law
    Worldwide Laws
De-Restricting 2024 Canyon Strive:ON
MrSimmo
1,096
1,047
The Trail.
Hi all,
I'm looking to buy a 2024 Canyon Strive:ON.
I'm coming from a derestricted Levo which is an easy derestrict and (apart from an incorrect speedometer reading) works perfectly.
I admit I'm confused with the options for de-restricting the Bosch systems.
What I'd like to avoid is any solution that requires me to:
- Leave the bike on for a prolonged period of time after a bike ride
- Push the bike home after the system detects a hack
- Use a powerdrill or something on the bike to spin the cranks
I also have no need for the Bosch display screen and don't care if the warranty is voided; I also dont mind if the speedometer is wrong.
Does anyone know (or if anyone has) de-restricted the new Canyon Strive:ON with the Bosch CX (either normal or race) motor?
(Happy to PM me privately as well if you're not comfortable disclosing if you have de-restricted publicly).
Cheers
DOMBUSH
56
15
Cambridge
Hi all,
Cheers
Hi - I fitted a 1.2b Speedbox to a late 23 Strive-on. Tried many signal generator positions and managed to get it working for approx. 30 - 60 secs at a time before error. The most successful signal generator position also fouled the frame.
Summary of approx. a day's:- fit, test, error; - move - fit, test, error; etc. was I just couldn't make it work.
Discussion with others that have tried, is that Bosch are monitoring the rim-magnet, magnetic field, wave-form with a level of sophistication that the derestrictor cant mimic.
I spoke with the manufacturer and they admitted issues.
Bosch 1 - De-restrictor 0
MrSimmo
1,096
1,047
The Trail.
Thanks Dombush, thought that might be the case. Thanks for letting me know. I might avoid Bosch and the Strive on in in that case!
MrSimmo
1,096
1,047
The Trail.
As a side note - If anyone can get hold of a copy of the Bosch firmware, I can ask around to find someone who can reverse engineer it and remove the limiting code. That would save the need for hardware de-restrictors.
554K
