ABMichal
Česko
Someone will probably kill me, because this is a “repost” of my post that i made yesterday and no one has answered. So i hope this time someone helps. :D
Hi, i still have a problem with creaking crank arm?! Well my bike was creaking a lot and i have checked bolts on motor and they seem fine (even though i f*cked one small bolt). Well i kinda found out that the creaking comes from the crank arm bolt, yesterday i have torque it somehow and well it almost worked like a charm, it still creaked but rarely and very little. But as i know it was crank bolt i have borrowed a moment wrench. Put 40Nm there and… it started squeaking. And as i put more Nm it starts to be stiff and when i put less it starts to creak and squeak. Im lost!
Anything that i can do about it?
Bones
871
1,118
Harrogate
Take the crank arms off and put a bit of grease on the splines. It also seems like the bolt could do with a tiny bit also. Try that and see how it goes 👍
Jasonr6
Kent
I have the same problem it’s the problem been informed it’s the case of new lower frame 🤦🏻
Paulcampbell65
Canberra
mines not a frame creak but a similar intermittent bearing type squeak on forward stroke rhs - crank area - will have to go thru dealer to try for a warranty - as i only have 1000klm on it - is it 2 years or more?
i just know it will be no fault found or heard!!!!!!!
552K
