Cube action team hybrid 160, 2021, motor bolt torque
MrPeaski
260
210
South Wales
20nm might be ok if your frame is aluminium, but not for carbon.
I'm sure a user here posted a picture of a damaged carbon frame from over torqued motor bolts.
Try the search engine on the forum, as I'm sure I read them here somewhere.
MrPeaski
260
210
South Wales
This was the thread I was thinking about
See post #71 for the outcome and the proper bolt torques
6nm for the small bolts that hold the plates onto the motor, 11nm for the larger bolts that go through the frame into the plates/motor
Just an FYI, the bolts are Torx+, not regular torx.
552K
