Other Creo SL Update and Calibration
mathiaspap
24
Cyprus
@Specialized Rider Care does the Motor need calibration after firmware update every time?
I just received my Creo SL a couple of months ago and last week took it in to the dealer for the latest firmware update. After the update the dealer attempted to calibrate the motor, but it was contantly failing as he got an error message that the sensor temperature was out of range. Therefore the motor was not calibrated following the firmware update.
Is that OK or does it need to be calibrated after the firmware update. I since went for a ride and found the reported rider power on my Wahoo slightly elevated, but again this could just be my impression, its impossible to judge if rider power is 'correct'.
Thank you
ThierryGTLTS
119
55
Belgium
Thank you
My dealer has just performed the 4 updates (motor, battery, TCU, and TCD) and everything was perfectly done, so I can't help you.
552K
