CREAKING ISSUE: Cannondale Moterra with Performance line CX gen 4. At 4600km and 2nd trip to LBS, the motor was replaced. The creaking was very loud when putting force through the pedals. Tightening the main motor mounting bolts gave a temporary fix (first visit). Bosch didn't hesitate to swap out the motor, which makes me suspect they know this issue. The motor was still ok, but something to do with the mounting plate/bracket attached to the motor. Lucky still under warranty. I do at least 6000km/year mostly commuting plus hardcore trials. Mechanic said another bike was in the shop with same issue. There are other Bosch creaking reports on the forum.
These motor warranties should be distance based, not time based. A weekend warrior might only do a few thousand km after 2 years then the motor fails, and then they are faced with an expensive repair/replace cost when they really didn't get much life out of the motor. On the plus side, if my motor keeps failing within the 2 year warranty, my bike will always have a new motor !
Begs the question - what is the km life expectancy of these motors? When should they be serviced?
Anyone else experienced creaking issues with Bosch gen 4 motors? After how many km?
