How are these compared to Shimano’s old “Trail pedal”. I like SPD, but are considering trying CB e mallet. I often struggle a bit clicking inn fast enough afterwards when things get a bit rowdy.Five Tens with Nukeproof Horizon clipless pedals. View attachment 269
Those Oneups look well tasty ?Have Hope F20 flats on my ebike which are great but think they will be getting changed after I tried OneUp Component pedals on my regular bike. The OneUp pedals with pins are as thin as just the body of the Hopes and are a little narrower which helps with ground clearance.
I used to ride clipless, would get fed up with the mechanism bunging up with mud in winter, the final straw was when I twisted my ankle and I couldn’t ride with my foot clipped in. Went on flats with the obligatory 5Tens and never went back. Was tempted when a couple of friends tried CB Mallets like Jonas just suggested with the more open design mech.
View attachment 277 View attachment 278
“Trail pedal”?
Do you mean these?
If so, they are a bit harder to clip back in to because of the studs but offer more grip when not clipped in and more support all the time because of the larger platform.
“Trail pedal”?
Do you mean these?
No idea, never used them, but they don't look to offer much support and I hate to try and use them in sloppy conditions without clipping in.
Sorry, only ever used SPD. I considered CB some years ago but there were doubt over their longevity.Hi,
In general which are easiest/quickest to click into SPD or CB ?
The Crank Bros egg beater style have an open design which has far less issue with mud, you don’t have to be quite so accurate on foot position to clip in and they generally offer more side to side ‘float’ which is an advantage if you have iffy knees. ( no advantage with Mallets or E Mallets as the pins hold your feet in position once clipped in) big downside is you cannot adjust the release tension like you can with SPD’s and as mentioned reliability & aftersales can be a problem.Hi,
i use multi release cleats gives a sort of half way house
Not seen those before , looks like shimano realised they needed to make a pedal like the nukeproof they look goodView attachment 749
Had these for a few weeks, Saint PD-M820, very nice.
