Rail (625Wh) clicking noise???
Jan 26, 2023
87
72
England
i'm getting a really annoying clicking noise when i pedal (trek rail 5) its coming from the head set deffo not the crank.
would it be a clicking /cracking noise if the head set needs a bit of a service?
DeRailled7
59
170
Calgary, Canada
When my headset starts to creak it’s usually a sign it’s time for a bit of maintenance. All that’s usually needed is cleaning and reapplying some grease. Doesn’t matter how log it’s been since the last time it was done. If you’ve been riding a lot, if its been wet, dust, muddy, doesn’t matter, dirt will find it’s way in. Its also a good time to check wear on your bearings. I will also pack the bearing with good quality waterproof grease. Even if the bearings are said to be sealed, it doesn’t mean 100% sealed. Often i find that the bike shops are not very generous in applying grease when they put a bike together, i.e. new bike. I would do this quick maintenance before taking it to your bike shop, if the creak is still there you could at least rule out this one.
554K
