How to use this section. To the thread starter: Once you are satisfied with the answer that youve been given, click the Trophy on the left hand side of the message. This will rate this answer as the 'Best Answer' and will change the question status from 'Unanswerd' to 'Answered'. All members can also upvote an answer with the 'Up' arrow, this will help identify the best answer.
All electrical contacts are subject the oxidation and that in turn retains dirt and moisture. Electrical contact cleaner removes the oxidation deposits and with it the dirt. Some contact cleaners also contain a lubricant....as always you get what you pay for.
If badly oxidised, buy a fibreglass cleaning pencil from amazon or ebay for a few quid. Just twist the base of the pencil to expose the stiff fibres then rub over the electrical terminal to clean it. Finally spray with a contact cleaning/protecting spray.
No it will just attract dust and dirt. Using some lubricant on the "o" ring and some grease on the chamfered mating surface of the motor to battery connection helps keep the contacts area protected from both water and dust.
