Charger 2.1 leaking
RustyMTB
2,981
7,201
I noticed last night my charger damper is leaking around the compression adjusters. I've had a look around & found this is quite common on charger 2 dampers & comes down to a design flaw where the bladder doesn't generate enough pressure to energise the compression seal.
Rockshox's standard response is to replace the damper. Having watched a couple of repair videos, I can see why they say that. It is a very involved disassembly to replace a single o ring, so I'm on the horns of a dilemma. I can replace or repair but I'm interested in other people's experiences to work out the best way forward. For example, I don't really want to spend £250-£300 on a damper if the same fault is likely to recur in a couple of years time.
Open to suggestions.
RustyMTB
2,981
7,201
OK, so on reflection & watching this guy, the calculation is I either replace the damper for £££'s or spend £3 on o-rings & repair it. Going to be a long job & no guarantee of success but it's already broken, so might as well go for it.
568K
