Cadence
flash
1,058
995
Wamberal, NSW Australia
You don't actually "have to" spin at any particular speed. All mid drive motors operate within a range of cadences.
all of them drop off their assiatance output considerably at genuinely high cadences.
Yep. I realise. It's just that I feel like the E8000 provided more assistance at lower cadences than the EP8 (I still have both bikes to compare directly). The EP8 doesn't seem to want to pull me up a decent incline at very low cadences like the old motor did. I'm still leaning the new motor and playing with the software but, for me, it feels like the EP8 sweet spot is smaller than the E8000 and also higher in cadence.
Gordon
MRED_mtb
Everett WA
Curious.... I've always had the bad habit or preference to push harder gears at a slower cadence... which of the current motors out there are suited for something like that? Do any do better for slower peddlers?
rod9301
175
109
US
Yamaha cuts out at high cadence. But i think all do well at low cadence, if they have a torque sensor.
6,856
5,306
How much motor assist is provided at different cadences is largely defined by each motor manufacturers firmware. The Brose motor as used by Specialized ( and with firmware designed by Specialized) provides more support at lower cadences than a Bosch Gen4 for example. Typically in Trail mode with the Brose motor you get good support at a cadence of 40+ whereas a Bosch Gen4 requires a cadence of 60+ to get similar degrees of support. If the Bosch Gen4 is Bosch Smart System, the riding modes can be tuned in the Fow App and with the right settings more power at lower cadences than the standard tune can be achieved.
The best battery range and least wear and tear on the drivetrain for most motors is to engage a gear that requires low torque input from the rider. I have no experience of the Shimano motor so do not know how it compares.
578K
