Banktramp
Evening all
i currently have a set of SRAM Level T brakes on my 2019 turbo levo base model, it’s 4 pot at the front and 2 pot at the rear. I’ve came across a few options and would like your advice. I’ve just put new 200mm rotors on my bike and looking on pinkbike I’ve found a set of 2019 SRAM Guide T in mint condition for £100 or a new set of 2020 SRAM G2 RS for £180.
Main question is would you bother upgrading from Level T to the Guide R or jump straight to the G2 RS is there much difference between the R & G2?
Also as the cables are internal could I just swap the levers and callipers over and use original so I don’t have to feed them through the frame.
