Bottle cage for e160s
billium
109
95
Sussex
I was able to fit the Fidlock 590 with a minor mod. Its hard to tell from the pic but there is about 2mm clearance from shock to hinge
Because Fidlock decided in their wisdom that the best place for the hinge was at the back of bottle , I had to add a couple of washers to pad the bottom mount to pivot the bottle a little but it works.
Ark
466
401
Newcastle Upon Tyne
Wleding or whatever on that frame above looks kinda messed up btw, just above the motor why does it has a weird double line
450ml is the largest you can go to and thats with changing the mount around too
or just get a bottle cage where the bottle goes in from the side and a 600ml bottle like I posted about in this thread ages ago
Pumps not attached to the bottle cage which I think is an ELITE one, it just uses the same screws.
but I use a 600ml bottle and the shock never touches it
576K
