GrahamPaul
Can anyone point me towards a video/instruction manual for changing the chainring on the new CX Gen 4?
one of the main reasons I bought an hardtail instead of full sus. As the bike was gonna mainly be used for commuting I thought a 34t chainring was too small.Hey!
Im having same intentions.
Im guessing just to take crank off (allen key) and then the lockring which requires specific tool. Ive tried to search right tool but those are little under a bush. found somewhere bosch's original key that cost like 60e.. trying to find cheaper one.
In my Cube Stereo Hybrid 140 i have 34t chainring.
Going to try 38t ring.
I think something like this would do it .. I have one for the Kenevo and think it's the same one on the Bosch ..
I believe, due to it's "rampart" shape .. it's called a castle nut tool.
www.amazon.fr/dp/B07NR26FY1/ref=pe_3044141_189395771_TE_dp_2
Yep that thing have many names. Spider tool, lockring tool and castle nut tool. Different Bosch motors have different diameter in the nut. That one fits gen 3 motors. not sure about gen 4, maybe!
Yes.it seems to indicate the lock ring has a left-hand thread if I read the "Open<->Close" description correctly. Do I read this correctly?
It's not.I see that this is a Gen 2 tool, but I'll do a measure up to see if it is the same.
The Gen 2 did, I haven't tried a Gen 4 yet.Does the centre allen key bolt have a standard right-hand thread?
Notice, however, that this Park BBT-18 seems to reGo to Park Tools USA website and see the following:
BBT-18
-Shimano® Octalink® right side bottom bracket cup with external notches
-Bontrager® ISIS Drive™ bottom bracket cups
-Front chainring lockring for Bosch® Gen 3 and Gen 4 e-bike systems
I haven't used it myself, but Calvin at Park sent me that info.
I ended up buying the Unior 8 Tooth Cartridge Bottom Bracket Tool - 1671.2/4.Go to Park Tools USA website and see the following:
BBT-18
I emailed Unior and they say this one fits. The Union tool uses a standard 1/2" drive to attach to a breaker bar or torque wrench. The Park tool uses an eight point configuration which means you need a 12 point socket, or a 36mm crow's foot to torque it to spec.
So I'll see if the Union version works for me when it gets here.
Does it have a tooth extractor ?Thanks.
I already had misgivings about the Park Tool kit because of the need for a crows foot spanner.
I'll follow up on the Unior once our lockdown has ended and I can actually get to my garage again.
The Union tool works perfectly. But I am frustrated with the Bosch aluminum locking ring. My Rail had a thin o ring between the chainring and the locking ring. The ring has a torque spec printed (25-30 nm). My torque wrench only reads a torque value clockwise, and this ring is tightened anti-clockwise. When tightening the chainring locking ring, the o ring bunches up and doesn't lay flat, even with a little grease. Also, the locking seems to shed aluminum bits when coming on and off. The chainring sort of wobbles on the Bosch spindle before it is tightened down. I am not impressed with how it works. The steel e13 chainring presents a 52mm chainline. I wanted more clearance between the chain stay and the chainring so I bought the e13 alloy chainring which specifies that it makes a 53mm chainline. However the chain guide rubs with the alloy chainring. The spacers for the chainline are plastic 4 or 4.5 mm spacers, but that isn't enough for a greater chainline. It's all sort of a hassle.Notice, however, that this Park BBT-18 seems to re
I haven't found a Bosch manual that has instructions for installing the chainring. Apparently it isn't a user level maintenance action. The Bosch Performance Line CX user's manual says that all these actions must be performed at the dealer.The Union tool works perfectly. But I am frustrated with the Bosch aluminum locking ring. My Rail had a thin o ring between the chainring and the locking ring. The ring has a torque spec printed (25-20 nm). My torque wrench only reads a torque value clockwise, and this ring is tightened anti-clockwise. When tightening the chainring locking ring, the o ring bunches up and doesn't lay flat, even with a little grease. Also, the locking seems to shed aluminum bits when coming on and off. The chainring sort of wobbles on the Bosch spindle before it is tightened down. I am not impressed with how it works. The steel e13 chainring presents a 52mm chainline. I wanted more clearance between the chain stay and the chainring so I bought the e13 alloy chainring which specifies that it makes a 53mm chainline. However the chain guide rubs with the alloy chainring. The spacers for the chainline are plastic 4 or 4.5 mm spacers, but that isn't enough for a greater chainline. It's all sort of a hassle.
I ended up to order new 36t chainring and gave it to my local bike shop to change it when i took my cube to first maintenance, cost 25€.
I ended up to order new 36t chainring and gave it to my local bike shop do change it when i took my cube to first maintenance, cost 25€.
I have not done that. Are they responsive?Oh! That is not good.
Have you tried getting the information directly from Bosch via their helpline?
