Yea it seems a few have had this error and new motor is the fix .. I think it’s some internal sensor failure and Bosch just sen out a new motor as the units are not repairable by the dealers@Davidwylie I suffered this error message today, Bosch motored Cube 160, Gen 4 etc.
Was this a new motor job?
Have you tried charging the kiox from a USB cable?Kind time of the day. After the master was able to fix my engine, the Kiox cycling computer stopped charging, the master says that the computer is powered by 4 volts, but does not take charge. Perhaps someone can tell you what voltage should be during charging? There is no information anywhere about this, perhaps someone faced such a problem?
yes, from yusb it takes charge, it looks like the problem needs to be looked for in the motorNew motor has arrived, see if this one lasts longer.
Good day. Someone might know what voltage must go from the motor to the kiox for it to start charging?
w so I brought it home, removed the motor cover and unplugged the lighting (confirmed issue persist), and at this point left a fan running pointed at the exposed motor.
in my bosch 2 the water came in through the wiring of the lighting... see photo
I have a R&M bike with the Nyon display now for two weeks, used the bike for 100 Km at most, and the bike never encountered a drop of water. I got the 550 error two times now in one day. It happened when I turned on the bike, waited a minute or so, got the error, turned the bike off and on, and drove away. I didn't noticed anything wrong during riding. I checked the Nyons battery level, and seems fine. Not sure what to think of it, but water cant be de cause. I will wait to see if it keeps coming up.
Are you sure about the 2 year warranty starting again. Here ist is limited to the age from purchase.Hi
re Bosch gen 4 . I have 1500 miles on the clock , purion display cut out but. Power for assistance remained (thankfully)
then couple of hours later purion came back on. Thought it was damp ,it was a very wet night ride, but I took it for a diagnostic check . It threw up NO error codes. Went for a ride and 200 yards later all assistance and purion went off, back to shop.they checked and the 550 error code came up!
they checked the purion ,checked the battery, checked connections , finally after submitting details to Bosch, they received a new motor!
two year warranty starts again.
the bike has been test ridden with no problems ,
