Bosch gen 4 chainring e13
Rostle32
85
91
Uk
I’ve just swapped over my drivetrain completely, from 12 speed shimano to 10 speed, due to supply shortage/prices of 12 speed stuff!
All gone sweet except my front chainring is sucking slightly due to being 2500mile old !??
Trying to source a Bosch gen4 E13 chainring 34T 52mm boost, steel
anyone know of a supplier who can ship into UK ?
All help greatly appreciated ??
Rostle32
85
91
Uk
Well, panic over !! Managed to source a new chainring ( OE) shipping is dear and due in stock in May, but .....
here is a link :-
E*THIRTEEN Chainring e*spec Direct Mount Bosch CX Gen4 | Steel 34 teeth
  • E*THIRTEEN Chainring e*spec Direct Mount Bosch CX Gen4 | Steel 34 teeth
Item number:
44162-001
Product weight:
182 g
Manufacturers:
e*thirteen
29,50 €
MSRP: 29,90 €
You save 1,34%, that is 0,40 €
including 19% VAT. , excl. Shipping costs / shipping time info
Availability:
May 2021
version
34 TEETH Please select34 teeth36 teeth38 teeth
ADD TO BASKET
WISHLISTQUESTION ON ITEM
Dr. Ergal
46
73
Italy
I'm still wondering why E13 does not produce a 30T or 32T chainring
It would be perfect to me (34T is too big for my personal usage of the bike, with the minimum motor assistance I can)
Mteam
1,859
1,792
gone
When my 34 tooth chainring has worn out, I'm going to go for 32 tooth. so its good to hear it works fine.
I was wondering if you needed to tell the motor software you had a 32 tooth ring, because the chainring size is a parameter in the software, but it obviously works fine for you
Gyre
630
421
Pasadena, CA
I made the change probably around last August give or take, so it's been awhile. I haven't been to a dealer since then so if it's a dealer controlled parameter I definitely didn't change anything.
551K
