xxxnutz
Bosch have made various adjustments to the modes between the two versions you have . Mine started on v1.1 and was quite abrupt on startup which made it quite tricky to start on steep loose terrain. I had the firmware updated and this definitely toned down the initial startup power and made it easier to get going without wheelspin on steep stuff.
I'd guess it's this difference in firmware versions you're feeling,rather than something due to wheelsize differences.
My conclusion is the firmware after speaking to various peoplemy bike is on 1.1.5.0 and is 27.5 and power delivery is not immediate so as a bove it could be firmware related. It could also be the difference in freehub engagement and rear suspension kinematics on each of your bikes. A bike with more compliant rear end design will absorb a degree of the initial toque you apply to the crank compared to a design with greater pedal efficiency.
I'd avoid 'stabbing at the pedals' you'll shag the internal gears of the motor. Many are only nylon plastic. Not up to that level of abuse for long.
So which bikes are these ?, i ask this as theres bound to be a difference in weight, which might account for any differences.
