Bosch Drive Unit Performance Generation 3 (65Nm) change display
omn
Norway
Hello all.
I have just bought a new elbike and want to change from Bosch Intuvia to Bosh kiox , smartphone hub or nyon. If i do that do i have to put new cabel from engine to the new display. or just use the cabel that is for the intuvia.
indie1982
7
The Hills
Yes, you'll have to change the motor cable unfortunately. The Nyon (2020), Kiox and Smartphone Hub share the same type of motor and controller cables, but unfortunately the cables that are in use on the Intuvia have a slightly different fitting at the handlebar end and aren't compatible.
551K
