500 to 520 grams for the pair.Im curious to know how much heavier aluminium is by comparison. Any idea?
non, 160 is the shortest
only pinnd and Hope are 155 and 145 but alloy
Cool. Thanks. I thought the savings would be greater. Good to know200g + 200g + 200g ...
I use Miranda 150mm and do like them. They are the cheapest, for sure. And they ship lightening fast! Had no idea they were so heavy!Miranda 155 eBike cranks, about £45-50 from Amazon UK. This is our spare set which is View attachment 146611 without self'extracting bolts which can be removed from our existing Miranda cranks if necessary.
Edit: Wanted but couldn't find 155mm lightweight (~350g) carbon cranks anywhere so went with 155mm alloy cranks which all seem to be about 450g+
I bought three sets if these 150-155-160 so I could determine which was suitable for different applicationsI use Miranda 150mm and do like them. They are the cheapest, for sure. And they ship lightening fast! Had no idea they were so heavy!
But they don't deal with abuse very well. I'm on my 5th set. My fault, of course. I tend to pedal through and around everything and get some wicked pedal strikes, especially around fast corners.
I'm focusing on recognizing where potential pedal strikes exist if I choose to pedal, and I am opting to coast through these areas now. And as Martha always says, "that's a good thing".
Still considering Hope, but they are pricey!
Pedal strikes transmit side load potentially causing internal motor damage. Stiff cranks transmit more side load than cranks which bend. Side loads have to go somewhere, so take your choice: bent cranks, or stiff cranks with higher risk of motor damage.I use Miranda 150mm and do like them. They are the cheapest, for sure. And they ship lightening fast! Had no idea they were so heavy!
I agree with this 100%, and thank you for reminding me about this important consideration.Pedal strikes transmit side load potentially causing internal motor damage. Stiff cranks transmit more side load than cranks which bend. Side loads have to go somewhere, so take your choice: bent cranks, or stiff cranks with higher risk of motor damage.
