Hi everyone! I welded up a frame that I want to be dual purpose analog/ebike SL, and so I have an adapter for a trad bottom bracket or a mount for a Bafang m810.
I need to build a DIY battery that can fit in the downtube, which is 48mm inner diameter. 4 18650s should fit, and that would require 8 rows plus one extra battery hanging out (33/4 = 8 r1). That last, 9th row that has a single extra cell would be the perfect spot for a BMS, but I don't know where to find one that can it inside a 48mm tube. Any suggestions?
Again, my requirements are 48mm inner diameter tube, 33 cells total in 11s arrangements. Any help would be greatly appreciated!
