Will be replacing my dropper to get the most travel possible as currently only have 110mm What is the largest dropper that can fit into a large size frame? Does anyone have a rough measure for max insertion length?
150mm dropper i think should fit, that's what I'm leaning towards at the moment. After doing some measurements of my current post, a 170mm travel post would be the perfect height fully extended if there was room enough to run it slammed/fully inserted inside the frame.
Hopefully someone has some experience, Thankss in advance!
