Bigger chainring
Giff
459
127
Cheshire UK
If I go to a 38t chainring from a 34t to move into the larger, lower sprockets more often, do I need to add 4 extra links to my chain length?
MrPeaski
260
210
South Wales
What the above table shows is basically for every 2 teeth you need at least an extra 5mm of clearance between the chainring and the closest part of the chainstay.
i.e to go to a 38 you need at least 10mm of clearance between the current 34 and the chainstay.
I'd also check that it doesn't decrease when the suspension goes through its travel
552K
