Axle i cannot get loose
Razorx
40
8
Sweden
I ha e a Scott egenius 730 plus and me and my friend tryed to remove the axle in this pictures. It mooves freely (it spins around) but we. Cannot get it off the bike!?
We tryed everything...anyone iwth any suggestions?
Screenshot_20240317_183635_Chrome.jpg Screenshot_20240317_183957_Chrome.jpg 20240317_010323.jpg
6,551
5,041
View attachment 136555 View attachment 136556 View attachment 136557
Assuming the axle is as per the part circled in your photo...and assuming the the hex nut circled has been removed from the non drive side it would then suggest the axle is drifted or pressed out..........ie press or drift appled on the non drive side and the axle drifted out the drive side. No doubt the bearing on the drive side will collapse since it looks completely shot!
The bearings can then be pressed or drifted out.
You need to remove the rear wheel and rear shock to take all pressure of the rear triangle first.
Plummet
Flash Git
Mar 16, 2023
1,152
1,634
New Zealand
Soak it in crc/wd40/croil.
Then punch/press out.
It's probably stuck due to grit and corrosion build up.
Not sure how much elbow grease to apply? Go to where you are comfortable.
Then take it too the bike shop if you fail.
Chillout83
Aberdeenshire
For that I would get some screwed rod put so suitably sized washers and nuts on it and get a socket on the other side to face against the frame and a nut and washer on the rod and and tighten to pull
Razorx
40
8
Sweden
Thank you.. I forgot to update this thread. We silver it this week just like chillout83 mentioned.
554K
