I completed a test today that helped pin down the assist value.
Can an eMTB be as much rider effort as a MTB? – Matter-Replicator
Just turn it off mate. it'll ride fine switched off and you'll experience the effort they are properly.Sometimes I want to ride on my eMTB with people who are on normal/manual/clockwork/acoustic/old-school bikes and want to experience the same effort that they have
I thought the jEsus Eeb's motor didn't cause any drag?I have seen people suggest 10%, 15%, or even 5% to make up for the weight and motor drag of the eMTB. My theory was that about 10% assist was needed to match the effort
Whatever drag there is or is not, I am trying to match up for it. I am pretty sure if I turn the bike off, I cannot match my time on a manual bike.I thought the jEsus Eeb's motor didn't cause any drag?
you could if it was a 50lb "manual" bike with the same tyres/components/geometry/suspension.Whatever drag there is or is not, I am trying to match up for it. I am pretty sure if I turn the bike off, I cannot match my time on a manual bike.
Aye. maybe in a wind tunnel on elevating rollers. in the real world cycling on actual roads with actual wind not so much.For example, I could replicate a road racing bike from a eMTB by calculating air drag from 0-20mph in 1 mph increments for both, and calculating how much wattage is needed at each speed to compensate for the differences in drag
An average of 0.9mph faster over the whole route is not the same as climbing at 0.9mph faster, riding the flat 0.9mph faster and descending 0.9 mph faster though is it? not to mention terrain differences and accelerations/decelerations.The 10% assist was 0.9 mph faster than my manual bike
Exactly. That is what I did.you can reduce assistance levels to get a similar average workload
I am not sure the peak power setting matters for me when assist is on 10%. I believe that 100% assist is 4.1x the rider input, so 10% assist is 0.41x rider input.
If PP is set to 30%, and the bike can max at 700 watts, then the bike can send 210 watts to the motor.
If PP was set to 49%, as I had it set, then the bike could send up to 343 watts to the motor.
So let's say I pedal hard and can put down 500 watts for a few seconds. 500 * 0.41 is 205 watts.
Whether PP was set to 30% or 49%, either would send the 205 watts and so there would be no difference in the motor output or battery consumption unless I was cranking more than about 500 watts (which I don't).
Interesting, thanks for posting.
Do you like the Schwalbe tire combo better than the Maxxis?
I wouldn't use this setting when alone as it makes no sense since once can just use, say 25% assist and still push your heart rate up and cover more ground.Who really gives a F if you are doing it easier on your eMtb than your mates on their non powered bikes. Screw that, why did you even get a eMtb for ? If you want to replicate what your mates effort then ride what they ride, a non powered bike.
Oh, you use Strava...carry on then. ?I wouldn't use this setting when alone as it makes no sense since once can just use, say 25% assist and still push your heart rate up and cover more ground.
But when with others, if you go on a ride with other people - you can't just speed ahead of them. And if you ride along side them with too much assist, you don't get much of a workout. I wouldn't ride with 10% assist when alone, except to do this experiment.
Look at my Strava feed to see how I normally ride: Strava Cyclist Profile | Robert Silvers
Ok then. Well... it's over ambitious to think that this can be done by simply adjusting motor output using basic user apps. Someone 'scientific' would have to write a complex and sophisticated software algorithm to take into account and then match the INERTIA of a heavy eBike versus a much lighter MTB. Just taking descending for example... there are accounts of some riders discovering that eBikes are often faster going downhill. NOT that more weight makes an object go faster, but that the heavier eBike maintains momentum better over bumps, and takes longer to slow down when braking approaching a corner - but yet is able to be controlled somehow because of the same extra weight spread over wider tyres is able to maintain traction... whereas a lighter analogue bike might start squirrelling. Software scripts may also need to be written to include engaging the brakes on certain moments to mimic the deceleration characteristic of a lighter bike, plus include actuators to re-posture your suspension travel depressions accordingly... BUT, there is no software in the world that would be able to produce and mimic lesser tyre traction due to lesser weight. Then there's increased stability and improved handling due to the fact that an eBike has a much lower centre of gravity because the extra weight is down low. In a manual MTB, the rider is significantly heavier than the bike itself so all that weight-bias is top heavy. In many ways an eBike may exhibit inherent 'unfair' advantages when descending - and motor assist hasn't even switched ON yet.Time to make this scientific...
I'm fortunate I guess... none of my friends ride eBikes but they all think it's awesome that I do, and they don't give me a hard time about it. They are often curious and so I let them ride mine and they all think it's great even if they're not interested in getting one just yet.Yeah, there are no other eMTB. I know of three people. One is selling his. One is in another state. One never rides where I go. I started a Facebook group for my state and I am pretty much the only person posting in it. eMTB is just not popular in the US. The first step to changing that is for the laws to change. They are not allowed where people ride MTB.
