Any 250+lb guys on the Spectraln? If so, what pressure are you using on the rear shock to set sag?
@ what body weight?I'ma guess somewhere around 310-320psi
pure guess based on the shocks max psi.@ what body weight?
Trying to get real world numbers. If I order a CFR and I cant set it up, thats a big waste of time. If it sets up @ greater than 50psi over body weight, I wouldn't order. It does run a Float X but unsure if they changed to a factory spec tune.pure guess based on the shocks max psi.
I'm similar weight with a different shock brand and I need the shock pumped up near it's max to get 25-30% sag
you can set it and find out without leaving the house,
What's the shock? google is telling me float x?
that guide says try started with the PSI set to your weight in lbs though so try 250 but it's probably going to be too soft by a lot
